TwinTurbo.NET: Nissan 300ZX forum - Re: BTW - another way to test. Leave gas cap tight, idle car
KY Z MAN
on March 13, 2018 at 11:17 PM
posted by jzack
on March 13, 2018 at 10:26 PM
will give that a try and let you know. Thanks
Code 21 ISC
KY Z MAN
00:46:41 03/13/18
Sounds as if you looked at all the right things. Give this
jzack
09:50:26 03/13/18
Re: Sounds as if you looked at all the right things. Give this
KY Z MAN
13:57:41 03/13/18
Generally not easy to fry. One cause can be failure to
jzack
14:13:07 03/13/18
Re: Generally not easy to fry. One cause can be failure to
KY Z MAN
14:49:41 03/13/18
The sitting 1 hour is also a good clue - leads me to believe
jzack
18:07:40 03/13/18
But it's positive pressure pump in the tank system
compirate
20:28:35 03/13/18
Lol, very easy. The tank has a vapor return line.
jzack
22:13:11 03/13/18
jzack
22:26:21 03/13/18
Re: BTW - another way to test. Leave gas cap tight, idle car -
KY Z MAN
23:17:44 03/13/18
KY Z MAN
01:15:23 03/14/18
But not technically vapor lock, more a vacuum lock,
compirate
01:00:25 03/14/18
Yep, agreed. (n/m)
jzack
00:31:34 03/15/18
Re: Lol, very easy. The tank has a vapor return line.
KY Z MAN
21:52:14 03/14/18
KY Z MAN
14:56:52 03/13/18
KY Z MAN
21:58:20 03/14/18
